I’m trying to insert and activate an item with price from excel and when the item from the excel is not present in the item table i need to export the items into excel from ax…
Here is my code importing is fine but exporting is not happening…
void clicked()
SysExcelApplication application,app1;
SysExcelWorkbooks workbooks,wbooks;
SysExcelWorkbook workbook,wbook;
SysExcelWorksheets worksheets,wsheets;
SysExcelWorksheet worksheet,wsheet;
SysExcelCells cells,cells1;
SysExcelCell cell;
COMVariantType type;
System.DateTime ShlefDate;
FilenameOpen filename;
dialogField dialogFilename;
Dialog dialog;
//Table Declarations Starts
InventItemPrice inventprice;
InventDim _inventdim;
InventParameters inp;
InventTableModule inm,inventTableModule;
InventItemPriceSim iips,inventItemPriceSimulated;
InventTable _inventtable;
//Table Declartions Ends
//field declaration
ItemId _itemid;
CostingVersionId _versionid;
CostingVersionPriceType _type;
Price _price;
PriceUnit _unit;
CostingVersionId _version;
InventDimId _invent;
InventSiteId _site;
TransDate _fromdate;
InventItemCostingType _costingType;
int row,row1;
#OCCRetryCount
#Excel
// convert into str from excel cell value
str COMVariant2Str(COMVariant _cv, int _decimals = 0, int _characters = 0, int _separator1 = 0, int _separator2 = 0)
switch (_cv.variantType())
case (COMVariantType::VT_BSTR):
return _cv.bStr();
case (COMVariantType::VT_R4):
return num2str(_cv.float(),_characters,_decimals,_separator1,_separator2);
case (COMVariantType::VT_R8):
return num2str(_cv.double(),_characters,_decimals,_separator1,_separator2);
case (COMVariantType::VT_DECIMAL):
return num2str(_cv.decimal(),_characters,_decimals,_separator1,_separator2);
case (COMVariantType::VT_DATE):
return date2str(_cv.date(),123,2,1,2,1,4);
case (COMVariantType::VT_EMPTY):
return "";
default:
throw error(strfmt("@SYS26908", _cv.variantType()));
return "";
dialog = new Dialog("Excel Upoad");
dialogFilename = dialog.addField(typeId(FilenameOpen));
dialog.filenameLookupTitle("Upload from Excel");
dialog.caption("Sales Price Excel Upload");
dialogFilename.value(filename);
if(!dialog.run())
return;
filename = dialogFilename.value();
application = SysExcelApplication::construct();
workbooks = application.workbooks();
try
workbooks.open(filename);
catch (Exception::Error)
throw error("File cannot be opened.");
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
try
ttsbegin;
do
row++;
_itemid = COMVariant2Str(cells.item(row, 1).value());
_price = cells.item(row, 2).value().double();
_site = COMVariant2Str(cells.item(row, 3).value());
select Costingversionid from inp;
_versionid=inp.Costingversionid;
breakpoint;
if(row > 1)
select firstonly iips;
if(iips.ItemId==_itemid)
iips.ItemId=_itemid;
iips.VersionId=_versionid;
iips.PriceType=CostingVersionPriceType::Sales;
_inventdim.InventSiteId=_site;
iips.InventDimId=InventDim::findOrCreate(_inventdim).inventDimId;
iips.Price=_price;
iips.PriceUnit=1;
iips.FromDate=systemdateget();
iips.insert();
InventItemPriceActivationJob::activateInventItemPriceSimExt(iips);
info(strfmt("Items inserted successfully for %1",iips.ItemId));
else
info(strfmt(" Items not inserted for %1",_itemid));
app1 = SysExcelApplication::construct();
wbooks = app1.workbooks(); //gets the workbook object
wbook = workbooks.add(); // creates a new workbook
wsheets = workbook.worksheets(); //gets the worksheets object
wsheet = worksheets.itemFromNum(1);//Selects the first worksheet in the workbook to insert data
cells1 = worksheet.cells();
cells1.range('A:A').numberFormat('@');
cell=cells1.item(row,1);
cell.value(_itemid);
cell=cells1.item(row,2);
cell.value(_price);
cell=cells1.item(row,3);
cell.value(_site);
app1.visible(true);
type = cells.item(row+1, 1).value().variantType();
}while (type != COMVariantType::VT_EMPTY);
application.quit();
ttscommit;
catch
Error("Upload Failed");
How could i export the error items ?
thanks
