I’m trying to update active price for items through excel, I added one button in inventitemprice form… when I try to update for 1 item its getting updated but for more than 1 item its not updating…
My code is
void clicked()
//super();
SysExcelApplication application;
SysExcelWorkbooks workbooks;
SysExcelWorkbook workbook;
SysExcelWorksheets worksheets;
SysExcelWorksheet worksheet;
SysExcelCells cells;
COMVariantType type;
System.DateTime ShlefDate;
FilenameOpen filename;
dialogField dialogFilename;
Dialog dialog;
//Table Declarations Starts
InventItemPrice inventprice;
//Table Declartions Ends
//fields
ItemId _itemid;
CostingVersionId _versionid;
CostingVersionPriceType _type;
Price _price;
CostingVersionId _version;
InventDimId _invent;
int row;
dialog = new Dialog("Excel Upoad");
dialogFilename = dialog.addField(typeId(FilenameOpen));
dialog.filenameLookupTitle("Upload from Excel");
dialog.caption("Sales Price Excel Upload");
dialogFilename.value(filename);
if(!dialog.run())
return;
filename = dialogFilename.value();
info(filename);
application = SysExcelApplication::construct();
workbooks = application.workbooks();
try
workbooks.open(filename);
catch (Exception::Error)
throw error("File cannot be opened.");
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
try
ttsbegin;
do
row++;
_itemid = cells.item(row, 1).value().bStr();
_type = new DictEnum(enumNum(CostingVersionPriceType)).name2Value(cells.item(row,2).value().bStr()) ;
_price = cells.item(row, 3).value().double();
_version = cells.item(row, 4).value().bStr();
//_invent = cells.item(row, 5).value().bStr();
if(row > 1)
//update into inventprice table
while select forupdate Price from inventprice where inventprice.ItemId==_itemid && inventprice.VersionId==_version && inventprice.PriceType==_type
if(inventprice.RecId)
ttsbegin;
inventprice.Price=_price;
inventprice.update();
info(strfmt("Price updated successfully",_itemid));
ttscommit;
ItemPriceActivated_ds.research();
else
warning(strfmt("Price can't be update for (%1)",_itemid));
type = cells.item(row+1, 1).value().variantType();
while (type != COMVariantType::VT_EMPTY);
application.quit();
ttscommit;
catch
Error("Upload Failed");
My excel file is
may I know how to update?
It might be a problem with the format of the Item number column. Your code is unable to identify the type of the column.
Try by formatting the column to Text
problem is with Excel format it is unable to read the integer type item number from your excel try this conversion from any type to str
switch(cells.item(row,1).value().variantType())
case COMVariantType::VT_BSTR:
accnum = strFmt("%1", cells.item(row,1).value().bStr());
break;
case COMVariantType::VT_DECIMAL, COMVariantType::VT_R4, COMVariantType::VT_R8:
accnum = strFmt("%1", any2int(cells.item(row,1).value().double()));
break;
case COMVariantType::VT_I1, COMVariantType::VT_I2, COMVariantType::VT_I4:
accnum = strFmt("%1", cells.item(row,1).value().int());
break;
case COMVariantType::VT_UI1, COMVariantType::VT_UI2, COMVariantType::VT_UI4:
accnum = strFmt("%1", cells.item(row,1).value().uLong());
break;
case COMVariantType::VT_EMPTY:
accnum = ‘’;
break;
default:
throw error(strfmt(‘Unhandled variant type (%1).’, cells.item(row,1).value().variantType()));
use your row number and write a string field(accnum) to store the result. hope this will help
Yes, I added and it is now updating all values…
But I’ve one more doubt does price will update without inventdim value or it is necessary to specify inventdimid?
ttsbegin;
ttscommit;
else
is this correct way to update or am I missing anything?
You need InventDimId. The prices are specific to site and product dimensions (size, color…)\
Try creating a record manually and see what fields are updated in that table.
Yes, kranthi.
Its not letting me to create a record when dimension isn’t specified…
So how should I update if my excel is having site value?
Use InventDim::findOrCreate() method.
Example:
InventDim inventDim;
inventDim.InventSiteId = site; // this is from excel;
inventPrice.InventDimId = InventDim::findOrCreate(inventDim).InventDimId;
if(row > 1)
breakpoint;
select _inventdim;
_inventdim.InventSiteId=_site;
inventprice.InventDimId=InventDim::findOrCreate(_inventdim).inventDimId;
_invent= inventprice.InventDimId;
while select forupdate inventprice where inventprice.ItemId==_itemid && inventprice.VersionId==_version && inventprice.InventDimId==_invent && inventprice.PriceType==_type
ttsbegin;
inventprice.PriceUnit=_unit;
ttscommit;
else
I’m getting an error when I upload my excel file as
At what line of code you are getting this error?
Some comments on your code.
select _inventdim; -> **why is this line of code? This may give you a wrong inventDimId.**
**You don't need this check in a while select.**
**You don't have to call research after updating each record. You can call it end of your code.**
**You are not using %. See this, [msdn.microsoft.com/.../aa589727.aspx](https://msdn.microsoft.com/en-us/library/aa589727.aspx)**
try
ttsbegin;
do
row++;
_itemid = COMVariant2Str(cells.item(row, 1).value());
_unit = cells.item(row, 4).value().double();
_version = COMVariant2Str(cells.item(row, 6).value());
_site = COMVariant2Str(cells.item(row, 5).value());
if(row > 1)
breakpoint;
select _inventdim;
current=InventItemPrice::findCurrent(_itemid,_type,_invent,_activationDate,_site,_costingType,false);
if(inventprice.RecId && inventprice.PriceType==CostingVersionPriceType::Cost)
ttsbegin;
select forupdate inm where inm.ItemId==inventprice.ItemId && inm.ModuleType==ModuleInventPurchSales::Invent;
ttsbegin;
inm.Price=_price;
inm.PriceUnit=_unit;
inm.update(true);
ttscommit;
info(strfmt("Price updated successfully for %1",inventprice.ItemId));
ttscommit;
else
warning(strfmt("Price can't be update for (%1)",inventprice.ItemId));
type = cells
I’ve modified some lines and its updating price now kranthi…
I declared inventdim table and
select _inventdim; is to select tat table.
I've one more doubt how to find the current active version, so that I can update the price for that version alone when we upload the excel file
You don’t need that select.
Look at \Data Dictionary\Tables\InventItemPrice\Methods\findCurrent
I’m trying to insert items in active price form through excel, here is my code
do
row++;
_price = cells.item(row, 2).value().double();
_unit = cells.item(row, 3).value().double();
_site = COMVariant2Str(cells.item(row, 4).value());
if(row > 1)
breakpoint;
select Costingversionid from inp;
_versionid=inp.Costingversionid;
inventprice.ItemId=_itemid;
inventprice.VersionId=_versionid;
inventprice.PriceType=CostingVersionPriceType::Sales;
inventprice.insert();
info(strfmt("Items inserted successfully for %1",inventprice.ItemId));
application.quit();
ttscommit;
Here is my excel file
When I debug itemid value is showing as 102, may i know the issue?
yes, I’ve done that it is some formating mistake in my excel file.
Now when I import my excel file items got inserted in inventitemprice form but the price isn’t getting updated in item form…Is there any method need to be called?
do
row++;
if(row > 1)
breakpoint;
select firstonly inventprice where inventprice.ItemId==_itemid && inventprice.VersionId==_versionid;
}while (type != COMVariantType::VT_EMPTY);
application.quit();
ttscommit;
this is my insert code, how can I update the sales price in item master form for the item?
You have to update the price on InventTableModule table for record with module type sales.
Should I do manually, kranthi?
Write the code to update the InventTableModule record after inserting into Price table.
select forupdate inm where inm.ItemId==inventprice.ItemId && inm.ModuleType==ModuleInventPurchSales::Sales;
ttsbegin;
inm.Price=_price;
inm.update(true);
ttscommit;
Is this right?
