Hi
Import excel Data to Ax with X++ code
Any body help me out…
Thanks in advanc…
Hi
Thanks in advanc…
Table.Date = excelWorksheet.cells().item(TotalRow,6).value().date();
try this it may help you…
static void ImportDatafromExcel(Args _args)
SysExcelApplication application;
SysExcelWorkbooks workbooks;
SysExcelWorkbook workbook;
SysExcelWorksheets worksheets;
SysExcelWorksheet worksheet;
SysExcelCells cells;
COMVariantType type;
int row;
CustAccount custAccount;
Name name;
FileName filename;
CustTable CustTable;
filename = “E:\CustTable.xlsx”;
application = SysExcelApplication::construct();
workbooks = application.workbooks();
workbooks.open(fileName,0,true);
try
workbooks.open(filename);
catch (Exception::Error)
throw error(“File cannot be opened.”);
workbook = workbooks.item(1);
worksheets = workbook.worksheets();
worksheet = worksheets.itemFromNum(1);
cells = worksheet.cells();
do
row++;
custAccount = cells.item(row, 1).value().bStr();
name = cells.item(row, 2).value().bStr();
type = cells.item(row+1, 1).value().variantType();
CustTable.clear();
if(!custTable::find(custAccount))
CustTable.AccountNum = custAccount;
CustTable.Name = name;
CustTable.insert();
while (type != COMVariantType::VT_EMPTY);
application.quit();
Naresh.
int row;
Name name;
FileName filename;
try
do
row++;
CustTable.clear();
CustTable.insert();
application.quit();
Naresh.
int row;
Name name;
FileName filename;
try
do
row++;
CustTable.clear();
CustTable.insert();
application.quit();
Naresh.
For Ex:
in Ax I have Table is Table_Test
Fields : No Name valid
100 Tensi Yes
200 betsn No
In this way I can store the values in Table
In excel I have values. with 3 fields .
I want to import the excel values to Table the record which ever have the valid is Yes only I have to import … for that what I have code. complete code…
Thanks in advance.
No offence man, but I wonder if Google search engine has been disabled for India… because this is such a general thing in AX for which you could easily find your answer in just few minutes by a little research…
Take a look at this:
how to add time (format data ) from excel to ax?
i solved my problem
