Hello forum,
I created a Form and Subform that are linked. The concept is similar like Sales Order.
For some reasons, the Esc Key is not functioned properly from the Subform. If I pressed Esc Key from the Subform the Subform cannot escape.
Experts, please help.
ZB
Typcially, escape closes forms in NAV. A subform cannot be closed if the main form is open. Can you tell me the behavior you expect?
kriki
3
Probably you have some cancel-button on your subform that intercepts the Esc-key. Your subform should NOT contain the standard Ok-cancel buttons.
Thank you kriki. That’s exactly the case. The problem solved. You rock!!!
