Hello All
I am getting this error when I am trying to post a Purchase Line for the second time.
Cannot create a record in Dimension history for documents (InventReportDimHistory). Type: None, . The record already exists.
Thanks In Advance
Hello All
Thanks In Advance
Hi Bobby,
To resolve this problem, install the hotfix . Then, you must run the X++ job that is named âupdateInventReportDimHistoryâ for each company.
supported hotfix is now from MSDN. find and try it will work .
Hi Rajkumar,
Thanks for your reply, I am getting this error in AX 5.0 (2009), Please let me know the hotfix details for this issue in AX 2009.
Thanks in Advance,
Bobby
Check partnersource for a localised hotfix. This does not happen in standard AX unless it was on a specific release
I checked on the Partner Source, there is no result for AX 2009. There is 1 result for this error on AX 4.0.
