Dear All,
Hai everyone, i want to ask about this kind of err message :
Cannot create record in Dimension history for documents (InventReportDimHistory). Type: None. The record already exists.
I encountered this when posting invoice for PO.
After i analized the pattern, i knew that :
Product type : service with no varians (not product master)
Partial invoiced from the same receipt Id
The second invoiced from partial invoice will trigger this error
Have anyone encountered this before? Is it a bug?
FYI, i have search about this kind of error. From the information, i knew that this error also happen in AX 4.0 and AX 2009.
Hendrianto
Its not a bug, seems not fulfilling the unique index property so the error message arises: ‘The record already exists.’
Just check the table ‘InventReportDimHistory’ there transrefid field isnot getting populated with correct number, so assign the number sequence correctly.
Hi Vishal!
Thx for your reply…
I have checked the table and my numbering sequence.
The last number in table is *568
The next number in numbering sequence is *569
There is no status list/pending number nin numbering sequence too
Btw, i aggree with your opinion. It is not bug.
I have check it in other environment and it goes well.
I wonder where is it goes wrong?
You have to check ‘TransRefId’ field, in your table i can observe it is POC- ######. just check its number sequence.
Dear Vishal,
Thx a lot! You helped me solved this issue.
This table (InventreportDimHistory) check unique of fields : InventDimId, InventTransId, TransactionLogType, and TransRefId.
When this all 4 field have same value with other record, it trigger the error message.
In my case, i set wrong numbering sequence for TransRefId.
Hahaha dumb me!
Thanks again Vishal!
Hendrianto
If someone encountering the same case like me,
Please check numbering sequence in AP Parameter - Internal invoice and Invoice voucher
Internal Invoice → numbering for TransRefId that i posted before
Invoice Voucher → numbeirng for PO Invoice
