Muneeb
October 29, 2013, 2:43pm
1
I am unable to open the Enterprise Portal Site in Virtual Machine of AX 2009 Version.
When I try to open, it gives the following error and nothing displays in the Internet Explorer Page.
URL: sharepoint/…/DynamicsAx
Service Unavailable
HTTP Error 503. The service is unavailable.
Can anyone please help me resolve this issue as I need to work work upon Enterprise Portal.
Awaiting for some valuable feedback.
Thanks in advance.
Muneeb
Check the services for SQL and check whether the credential are given correctly in SQL configuration manager (give the credential once again if exists). it may be because the password for the user id might be wrong.
DevAX
October 30, 2013, 1:54pm
3
Hi Muneeb,
Try to do the below:
Run cmd
Type IISreset
This will restart the iis service and can help in solving you issue.
Nitish
Muneeb
October 30, 2013, 2:33pm
4
Hi Kumaran,
Appreciate for your valuable feedback.
Checked the services , they are running as well as I checked the credentials too.
But I am still facing the same issue as mentioned above.
Thanks & Regards,
Muneeb
Muneeb
October 30, 2013, 2:34pm
5
Hi Nitish,
I appreciate for your valuable feedback.
I tried the above soultion many times. Moreover I did it post your suggestion too.
But I am still facing the same issue, as in it is still giving the same error as I have mentioned above.
Let me share more details which is as below:
When I try to Browse the EP site, it gives the above issue and after that when I go back to IIS Manager, the service "SharePoint - sharepoint80" STOPS
Thanks & Regards,
Muneeb
