Problem with Enterprise portal
OS: Win 2008 Server
DB: SQL SERVER 2008
I have installed Dynamics AX 2009 with Enterprise portal (with sharepoint services 3.0 SP2).
The installer can access the site an use the enterprise portal, but other users get “access denied” message.
I gave the other users EP_int and even EP_admin permission and also added them to the Sharepoint farm administrators
(like it says in the manuals), and I still do not solve the problem. I also unmarked the user access control in the control panel for the sharepoint to recognize AD users (the machine is not a domain controller).
What am I missing?
Shoham Ziv
You have to create the rest of the users in SharePoint.
Go to your EP site → Site actions → Site settings (in the upper right corner) → People and groups → New → Add user
If you have many users It’s good idea to use groups.
Thanks a lot.
I added all authenticated users to the EP site, and now it seems to solve the EP problems.
Now I get errors in the Enterprise portal regarding the analysis tools and reporting services.
I am a newbie to the Dynamics AX 2009 product, so any help will be appreciated.
Shoham,
I’m glad this worked for you, please don’t forget to verify the answer you think solved the problem.
When it comes to deploying SSRS and SSAS, this usually requires some time and consideration of your current environment.
I would suggest you to read the following documents, and then carefully plan and implement each step.
#### Microsoft Dynamics AX 2009 Installation Guide
#### Configure the Default OLAP Cubes
Microsoft Dynamics AX 2009 Business Intelligence Cube Reference Guide
Configuring Enterprise Portal and Role Centers with SQL Reporting
#### #### Configuring Kerberos Authentication with Role Centers
Thanks.
I will download these articles. I already marked your answer as a solution several hours ago.
Hi, I have installed Dynamics AX 2009 SP1 in 64 bit windows server r2 with Enterprise portal (with sharepoint services 3.0 SP2 64 bit) sucessfully. But I have issue on when Manage Deployments in AX 2009>Administrator>Setup>Internet>Enterprise Portal>Manage Deployments Click Manage Deployment cannot be run because Enterprise Portal is not deployed on this computer I was tried these steps given below Ax Setup and deploy EP without recreating the site. With Dynamics AX 2009 Service Pack 1 a new command line utility AxUpdatePortal.exe is installed in the C:\Program Files\Microsoft Dynamics AX\50\Setup folder that serves this purpose. You can execute the utility with the following command line parameters to update all local Enterprise Portal sites: AxUpdatePortal.exe -updateWebSites -iisreset . Dynamics AX 2009 Setup again as follows and it will still update your portal site with contents from the AOT: 1.Launch the Dynamics AX 2009 Setup from the Dynamics AX 2009 DVD 2.Click Next 3.Select Add or modify components 4.Click Next 5.Check the Role Centers and Enterprise Portal check box 6.Click Next 7.Enter the password for your Business Connector proxy account 8.Click Next 9.Select the Enterprise Portal site you want to update from the drop down list 10.Uncheck the Configure for Windows SharePoint Services check box 11.Uncheck the Create Web site check box (see attached screenshot) 12.Click Next 13.If you untick the option “Restart IIS after installation is completeted” then ensure you Restart IIS later on before using EP 14.Click Install 15.Wait until the setup is finished with the status Installed 16.Click Finish These above given procedure also done but till I have same issue… What am I missing? Thanks, Gajendiran
Hi, I have installed Dynamics AX 2009 SP1 in 64 bit windows server r2 with Enterprise portal (with sharepoint services 3.0 SP2 64 bit) sucessfully. But I have issue on when Manage Deployments in AX 2009>Administrator>Setup>Internet>Enterprise Portal>Manage Deployments Click Manage Deployment Manage Deployment cannot be run because Enterprise Portal is not deployed on this computer I was tried these steps given below Ax Setup and deploy EP without recreating the site. With Dynamics AX 2009 Service Pack 1 a new command line utility AxUpdatePortal.exe is installed in the C:\Program Files\Microsoft Dynamics AX\50\Setup folder that serves this purpose. You can execute the utility with the following command line parameters to update all local Enterprise Portal sites: AxUpdatePortal.exe -updateWebSites -iisreset . What am I missing? Thanks, Gajendiran
I have installed Dynamics AX 2009 SP1 in 64 bit windows server r2 with Enterprise portal (with sharepoint services 3.0 SP2 64 bit) sucessfully. But I have issue on when Manage Deployments in AX 2009>Administrator>Setup>Internet>Enterprise Portal>Manage Deployments Click Manage Deployment Manage Deployment cannot be run because Enterprise Portal What am I missing? Thanks, Gajendiran
This is a know bug of AX.
Try the following information:
http://msdn.microsoft.com/en-us/library/dd261467.aspx
http://blogs.msdn.com/solutions/archive/2009/02/04/axupdateportal-utility.aspx
