Hi.İ want to click a button and range a display method in my grid.How can i add range a display field.Anyone know this?
Hi Sinan,
Please explain me clearly.
Hari
If the field you want to filter your datasource is a display method, it’s not possible to apply a range on it. A solution would be to rebuild your grid datasource with a temp table containing a field populated with your display method.
regards,
Thomas
Hi.İ want to filter my display field.(You see black arrow).But i know display field cant filtered.So i create a new field and i create a job and insert record.(You see this picture “Bölge”) . My requirement is when this display field updated,My new field must be updated.i try modified methods,Updated methods but i cant make.Anyone know this how can i make.Can you share an example.
Hi Sinan,
Please refer this URL http://dynamicsuser.net/forums/p/69516/367503.aspx
Is it possible to use inner join the table in your grid form datasource? (http://www.axaptapedia.com/Display_method)
Please also share your display method code.
Hari
