I’m working on CustInvoice report in AX 2009. I want this report to display data based on Invoice Date i.e. CustInvoiceJour.InvoiceDate and it should appear group by each month.
After every month interval based on user criteria entered it should do group totals.
If the you are going to do a more analysis on basis of month on invoice data, i would suggest adding it as a field to the invoice table and doing a group be on that.
If not you can use a temp table with month as one of the field in that fill the data into it from the invoice tables. Use the temp table as data source for the report and do a group by on month. I will be a complete new report then.
If I use a temp table then how do I fill this table with only month value from invoice table. And when the user enters his criteria how system will do grouping on this temp table.
