Hello,
I created one fixed asset , and transfer that fixed asset to different dimension. when I do proposal for depreciation (for that fixed asset), line generated in journal with total depreciated amount. But I require to run that depreciation for each dimension that I had transferred. Means I require depreciated amount of each dimension. more lines should be generated as per the transfer history.
So please help me for above problem.
Thank you.
