Dear Experts,
Do you know the calculation of Depreciation method Factor in AX 2012?
As I researched and tested about this method, the only information I understand is:
- If Factor value is > 50, the depreciation amount increases over time.
- If Factor value is < 50, the depreciation amount decreases over time.
- If Factor value is = 50, the depreciation amount is the same in each period (or straight line depreciation).
https://technet.microsoft.com/en-us/library/aa572027.aspx
Above is the technet link for a scenario and testing results. However, I could not know how the depreciation amount is calculated based on the factor value.
If you have any idea or experience about this method, please kindly advise.
I would highly appreciate any of your comment.
Thank you in advance!
