I am using Ax 2009. I would like to know how to setup accelerated depreciation profile in Ax. It calculates 50% of the asset value in the first year, then linear ?
Do you know how to do this ?
Thank you.
Paul
Thank you.
Paul
You can use Factor method with digressive depreciation
If you select digressive depreciation, the amount of depreciation per period decreases over time.
or There is an only Option defining Manual Schedule.
