I have item has wrong in quantity and cost and unit of measure so that i create new item with same name then block old
then add new entries after correction .I decided to make data port export all entries to specified item to text file then change it and import again from tables item ,value entry,item ledger entry which fields will change in this.
before changes
quantity invoiced quantity remaining quantity unit measure
2.5 2.5 2.5 ton
value entry
cost per unit 635
i need after changes 2500 2500 2500 kg
cost per unit 0.635
My question after changes which fields i will change
are this only and when i change change purchase entry only
please help me if possible
thanks
