MSajidH
1
This is my first time posting here & I am in learning stage of MS Dynamic Navision 2009.
I have Actions Table ID 99001509 which is having morethan 3.5 million records.
Here my question is how can I delete all old records (keeping only one month recent records) via dataport.
I am having little Knowledge in Dataport upto Export & Export only but I do not know how to apply delete function in dataport etc.
Any suggestions willbe hightly appreciated.
Kind Regards
admin1
2
You can just use the DELETE function. You use it as “Rec.DELETE;” - but why do you want to use a dataport to delete it?
MSajidH
3
Hi Erik,
Thanks for your reply,
Currenly I am deleting manually from Object Designer T-99001509 by selecting records.
I am looking for an option from Dataport to delete such huge records in single shot.
If possible, Kindly guide me in a simple step.
Thanks again for your suggestions.
Best Regards
Why do you require data port ?
You can write report using T-99001509 and write a code on onAfterGetRecord Trigger as following
DELETEALL;
