Thank you for reading the post, I have a class which calls a form through menuItem, the form does some processing and derives value(s), now I want to capture/ use that value(s) in the calling class (or pass the values to the calling class). How can I achieve that?
A common pattern to catch args.caller() in form init() method, validate it (e.g. if (SysDictClass::is(args.caller(), classNum(MyClass))) and save to a strongly-typed member variable (e.g. MyClass myClass). Then, to set some data to the class requires just to call one or more methods (e.g. myClass.parmXyz(…)).
