get value from class to form
hi Friends,
i have a form say form ‘F’, this from has a menuitembutton say"B’ whose action is a class say ‘C’. now the senario is when i click on the button ‘B’ a dialog say ‘D’ is open , this dialog contain a dialog field for emplid. I want to get the value of selected emplid into the form…in some variable, so that i can use this emplid.
can u suggest me how to do this.
hi Manish,
For this senario u must write the “click()” in the menuitembuttton…
SureSh.
You can pass the empId as parameter to the class.
Raghav.
You can also use args class
args.name(formstr(nameofForma));
args.parm(emplid);
formrun = classFactory.formrun(args);
formrun.init();
formrun.run();
Gyan
you can use this code :
void clicked()
Args args = new Args(“CustTable”); // for axample cust table
FormRun formRun;
// Look up customer 1000 when the form opens
args.lookupField(fieldNum(CustTable, AccountNum));
args.lookupValue(StringEdit.text()); // or args.lookupValue(“send a paramater like 1000”);
formRun = ClassFactory.formRunClass(args);
formRun.init();
formRun.run();
formRun.wait();
//Dialog dialog;
//DialogField field;
//Form _form1 = new Form(“the form that u can open it”);
// _form1.AOTrun();
super();
jalal
