Hello,
im trying to deploy a entity store *.bacpac to azure SQL, i get this error below, what to do ?
The type initializer for ‘Microsoft.SqlServer.Dac.BacPackage’ threw an exception. —> System.TypeInitializationException:
The type initializer for ‘Microsoft.SqlServer.Dac.DacServices’ threw an exception. —> System.TypeInitializationException:
The type initializer for ‘SqlSchemaModelStaticState’ threw an exception. —> System.IO.FileNotFoundException:
Could not load file or assembly ‘Microsoft.SqlServer.TransactSql.ScriptDom, Version=13.100.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91’ or one of its dependencies. The system cannot find the file specified.
at Microsoft.Data.Tools.Schema.Sql.SchemaModel.SqlCoreAnnotationRegister.RegisterModelAnnotations(ModelSchema storeSchema)
at Microsoft.Data.Tools.Schema.Sql.SchemaModel.SqlSchemaModel.SqlSchemaModelStaticState.RegisterModelSchema()
at Microsoft.Data.Tools.Schema.Sql.SchemaModel.SqlSchemaModel.SqlSchemaModelStaticState…cctor()
— End of inner exception stack trace —
at Microsoft.Data.Tools.Schema.Sql.SchemaModel.SqlSchemaModel.SqlSchemaModelStaticState.get_ModelSchema()
at Microsoft.Data.Tools.Schema.Sql.SchemaModel.SqlSchemaModel.InitializeModelSchema()
at Microsoft.SqlServer.Dac.DacServices…cctor()
at Microsoft.SqlServer.Dac.DacServices.Initialize()
at Microsoft.SqlServer.Dac.BacPackage…cctor()
at Microsoft.SqlServer.Dac.BacPackage.Load(String fileName, DacSchemaModelStorageType modelStorageType)
at Microsoft.Data.Tools.Schema.CommandLineTool.Program.<>c__DisplayClass3e.b__39()
at Microsoft.Data.Tools.Schema.CommandLineTool.ValidationUtil.SafeFileAccessWrapper(Func1 action, Action
1 reportException)
at Microsoft.Data.Tools.Schema.CommandLineTool.Program.DoImportBacpacOperation(CommandLineArguments parsedArgs)
at Microsoft.Data.Tools.Schema.CommandLineTool.Program.PerformAction(CommandLineArguments parsedArgs)
at Microsoft.Data.Tools.Schema.CommandLineTool.Program.Run(String[] args)
at Microsoft.Data.Tools.Schema.CommandLineTool.Program.Main(String[] args)
