I am getting this error in Database management framework in AX 2012
"Could not load file or assembly ‘Microsoft.Dynamics.AX.DMF.PreviewGrid, Version=1.0.0.2, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified."
If any one is having idea how to solve this then please share.
Your post is not clear.At what point of time you are getting this error?
Follow this link.I think some file is missing.We need to find and copy the file from setup folder.
https://community.dynamics.com/product/ax/f/33/p/96125/181690.aspx#181690
At what point of time you are getting this error ? can you explain the problem briefly …
i am facing the same problem, when I am working with data migration framework .
when i opens the common → Processing group in that entity button at that time i am getting the below error .
Please advice
Phani.
