I’m working around File Exchange (Export) using Data Import Export Framework
(DIXF) , i want to add generate method to Find LineAmount
Purchline associated with the receiving line VendPackingSlipTrans
from PurchLine
table.I create the following script but i need a help :
[DMFTargetTransformationAttribute(true),DMFTargetTransformationDescAttribute(“Function that generate LineAmount”),
DMFTargetTransformationSequenceAttribute(11),
DMFTargetTransFieldListAttribute([fieldStr(DMFVendPackingSlipTransEntity,LineAmount)])
public container GenerateLineAmount()
container res;
PurchLine purchLine;
VendPackingSlipTrans vendPackingSlipTrans
if(entity.LineAmount)
select firstOnly purchLine
where purchLine.LineAmount == entity.LineAmount &&
vendPackingSlipTrans.OrigiPurchId == purchLine.PurchId &&
vendPackingSlipTrans.PurchaseLineLine == purchLine.LineNumber;
if ( ! purchLine )
entity.LineAmount = purchLine.LineAmount ;
entity.insert();
res = [purchLine.LineAmount];
return res;
