Is there an easy way to copy over the number sequence data from one AX environment to another?
In a test environment awhile back, we originally ran the wizard to generate all of our number sequences. We had to modify the format for many of them, as well as add a couple hundred more for different journal vouchers. We are trying to start with a clean database now in a new test environment, but we will be bringing in some base tables from the old environment. How can I bring in the number sequences into this new environment, instead of having to re-add and modify all of them? What tables should be included in my definition group if I should export and import the data? I have tried many combinations and continue to get broken records in the NumberSequenceTable, NumberSequenceScope, and NumberSequenceReference tables.
I am using AX 2012. Thanks for your help.
