Is it possible to toggle the “Visible” property on the menu items attached to a menu button on a form?
Additional clarification: I would like to turn menu items on or off using C/Side code, so that functionality can be hidden from some users, and be visibleto others.
You can add a boolean variable and assign it to menu button name field…
in OnAfterGetrecord trigger, based on the condition you can set it to visible or hide
CurrForm..Visible := ;
MenuItems are not dynamic. You can have multiple Menu Buttons with different Menu Items and show/hide the buttons accordingly.
I hope this post is regarding Menu Button–>menu Items… [8-)]
@ Mohana,
Do you mean to define a bool variable and assign it to the name property of the menu button.
Yes, that’s what I figured. Thanks for confirming it.
Yes.
