how to hide the menu item
How to invisible the different menu item in the menu option placed at the form level. So, that specific user can access the hide menu item and different user can’t see it.
We cant I guess
may be you can check the permissions in OnPush trigger.
Are you using classic or RTC?
we are using classic 2009 SP1.
Please suugest how to hide the menu item.
You cannot dynamically set the visible property of a MenuItem.
What you could do is to have 2 MenuButtons (with different Menuitems) on top of eachother.
Then make one button visible and the other invisible dependend on the user.
