Hi All
I want to change the warehouse of the purchase order at the status received or Invoiced.Or i need to transfer the item from the current to required through the transfer journal.
thanks
Hi All
thanks
After packing slip is posted or PO is invoiced, warehouse gets updated with the inventory.
Use either transfer journal or transfer order to change/update the warehouse.
Pranav…
Once it is in stock the transaction is written so you need to move it by journal or transfer order. Not sure I understand your requirement.
Received, Invoiced mean that the stock has been received, the change at the order level will not have an impact on that…You need a journal entry here.
I can’t seem to find the setting to allow this. Is there a particular module that I need to install before hand?
Which setting you are refereing to here and for what purpose?
Pranav…
