PO warehouse
I have a purchase order, and already post the purchase order. However if I want to change the warehouse on the purchase order lines, do I need to post the purchase order again so the master planning can pick up the changed inventory dimensions?
Once you have posted the PO, you can’t edit anything there. For changing the warehouse, either you need to post correction entry or you can use transfer journal posted on same date as product receipt.
Pranav…
Thanks Pranav,
What I mean for “Post PO” is click “Post → Purchase order”, not invoice it.
So you have only confiemed PO. In that case, you can change the warehouse and reconfirm the PO. That will work.
Pranav…
