we have a WPF application which communicates with NAV 2009 R2 via web service. Meaning we display data from NAV in our WPF app and also insert/modify them from the app.
One of our customers uses Change Log functionality in NAV but when records are inserted/modified from our app then no record in Change Log Entry table is created.
you seem to use xmlport parameters to get classes in .net code. that fine.
do following: encapsulate the code in the oninsert trigger to a function “CallOnInsert”.
within the webservice method “insert” in your c/al code call that function “CallOnInsert”. so this insert also runs through the whole code needed to create the additional objects.
If not changed in recent times (cumulative updates), the change-log does only work when data is entered in forms and pages.
It does not work when data is handled in reports, XML-ports or whatever. Tos use VALIDATE and INSERT(TRUE) don’t do it.
You have to handle it yourself via codeunit 1, functions OnGlobalInsert, -Modify,… (before NAV 2013) or functions OnDatabaseInsert, - Modify, … in NAV 2013+.
What we tried to do even in the very begining was to move calling of Change Log functionality in CU1 from OnGlobalInsert to OnDatabaseInsert in 2009 but did not help.
