Hi AXpert,
I just want to ask how to delete class in AOT or in project? I tried deleting a class in project with (usr) to restore it to default properties but I cannot delete the it even though the delete is not hidden when I right click then delete.
jemz
If you try to delete a class from a particular layer(Suppose USR) then all the modifications done in that class specifically in USR layer will be deleted and the class will roll back to the layer just below to USR layer.
Yeah sir I want to delete the class to restore it to the default bu I can’t delete the class? Is there something to do with X++ license… If i don’t have the license can I restore it to the default values?
thanks,
You should have X++ development license to create/delete a class.
you might not have tehr rghts to delete the class.
