I have created a contract class with 6 parameters and i have executed the report. it was showing 6 parameters inputs.
later on i have changed one parameter is enough with that it can fetch the data.
i am using one parameters. but while i run the menu item and even after clean the report and rerun.
it is coming with the existing 6 parameters.
i found in the administer of the user but i didn’t found the applocal folder to remove auc files through which it can be removed.
kindly help me to remove this issue.
