I have installed all the prerequisites of Business Notification for Navision 5.0 sp1 in a single system (OS: Windows Server 2003, SQL Server 2005). I’m using smtp.gmail.com to send the BN mails. But it cannot send mails to the recipients. It drops messages in the event log:
Source: Business Notification
Description:
The following exception occured when trying to send out notification email: The server rejected the sender address. The server response was: 530 5.7.0 Must issue a STARTTLS command first. m31sm1510722wag.31 at System.Web.Mail.SmtpMail.LateBoundAccessHelper.CallMethod(Object obj, String methodName, Object[] args) at System.Web.Mail.SmtpMail.CdoSysHelper.Send(MailMessage message) at System.Web.Mail.SmtpMail.Send(MailMessage message) at Microsoft.BusinessSolutions.BusinessNotification.NotificationService.SmtpDeliveryProtocol.SendSmtpEmail(String senderEmail, String recipientEmail, String subject, String body, String culture) Please make sure that you have configured your SMTP server correctly, and this machine can relay emails through that server, and that the there are no misspellings in the name (IP address) of your SMTP server you have specified. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Can someone please help?
