bdw725
1
I was wondering if it was possible to dynamically build a X++ statement and execute it. For example:
str sTable = ‘CustTable’;
str sSQLStatement = ‘’;
sSQLStatement = "Select * from " + sTable;
so that I could have one generic procedure that would accept TableName as a parameter, and I could do a select on any table based upon the parameter.
Thanks in Advance for any help
Brian
U can use the Statement and ResultSet system classes for this purpose.
this is a sample:
BuildTSQL()
str SQL;
connection cnn = new connection();
statement statement;
resultset rs;
int i=0;
LedgerAccount _AccountNum;
TransDate _TransDate;
SQL = “select AccountNum,TransDate from LedgerTrans “;
SQL += strfmt(“WHERE dataareaid=’%1’”,curext());
SQL += strfmt(” AND AccountNum=%1”,LedgerTable.AccountNum);
statement = cnn.createStatement(ResultSetType::Dynamic);
rs = statement.executeQuery(sql);
while ( rs.next() )
_AccountNum = rs.getString(1);
_TransDate = rs.getDate(2);
