Dynamic SQL query based on Table Mapping
I want to create a dynamics sql query in X++.
For Example, i have 2 Tables. 1) AX Staging and 2 ) AX Transaction
My objective is to import All the transaction from AX transaction to AX Staging table
I don’t want to use sql Query like
while select axTransaction
axstaging.Field = axTransaction.Field;
axstaging.insert();
I dont want to use above x++ sql.
I need SQL statment should be dynamic, In that case I will be using one more table AXMapping
where I will have AXStagingTableId, AXTransactionTableId, AXStagingFieldId, AXTransactionField.;
How can u utilize this process similar to DIXF. Here only difference is AXTransaction Table should behave like Excel sheet.
