I am using AX 2009.
I have a stingEdit control on my custom form, i have set its EDT to filepath. Now when i am doing stringEdit.Enable = False from the code the browse folder icon is disappear from the besides of strinEdit control.
I only wanted to disable the stringEdit control with the browse folder button icon.
Any help will greatly appreciated.
/Ashlesh
I think you cannot do that - disable will do the total field…
Hi Kranthi,
Thanks for the quick reply.
I also think so, but i have also written the code to disable the other controls at the time of loading the form. This time it works perfectly.
Actually i have a checkbox contorl, i have written the code to disable the other controls(stringEdit) on the clicked() event of it. The same thing i have done while loading the form. kindly review my code snippet of the clicked() event of checkbox control.
public void clicked()
super();
if(chkbWMDisabled.checked())
//Disable other controls
element.DisableControl(1);
else
//Enable other controls
element.DisableControl(0);
The only difference at the time of loading the form is, above code is not executing. Instead of i have done the manually disable code for stringEdit as below.
public void DisableControl(boolean boolFlag)
if(boolFlag)
txtWMDataFolder.enabled(false);
txtWMSupervisorPassword.enabled(false);
else
txtWMDataFolder.enabled(true);
txtWMSupervisorPassword.enabled(true);
The call for the above method “DisableControl()” is like, element.DisableControl(0); in my form’s datasource’s datamethod.
The above description is enough to get u some more clear idea about the issue? OR do i required to explain it in brief.
Again thanks for your support.
/Ashlesh
