I have my own Form. On which I am providing the facility to browse for the particular Folder using winAPI::BrowseForFolder functionality of AX. Now after selecting the specific folder and then click on OK button it will assign the folder path to my StringEdit control which shows the browsed folder path.
Please give some suggestions.
Ashlesh
rejser
August 19, 2010, 7:36am
2
Any str field in ax with extended datatype filepath will automaticly do this, or am I missing the question?
selami
August 19, 2010, 7:37am
3
Hi Ashlesh,
you can use this code for selectfolder and set text
str filePath;
filePath = winAPI::browseForPath(element.hWnd(),“Select folder”);
if (filePath != “”)
StringEdit.text(filePath);
Regards
Hi Selo,
Your reply is helpful to me. Thank you.
But still I am getting the error. Please have a look on the image i have attached to review my work flow.
Please review it and let me know if you are not able to view the image.
Thanks for everything.
Ashlesh
selami
August 19, 2010, 8:47am
5
hey,
you have to set Yes for txtWmDatafolder AutoDeclaration propertie, after then you can access this control in the code scope.
regards.
rejser
August 19, 2010, 10:05am
6
If you don’t want the button you could just set the string-edit method’s extendedDataType to FilePath.
This vill get you a nice folder-button right by the field automatic.
You may have to add a method to the forms method by the name filePathLookupTitle
It may look like:
str filePathLookupTitle()
return ‘Lookup Title: Boll’;
This would result in:
Here the field is just a stringedit, not connected to any database/table
It may look like:
Oscar,
Thanks for the wonderful suggestion.
Actually i required to get the selected Folder path not File path. So to set the ExtendedDataType property to “FilePath” I can select File path but not the Folder Path which is expected by me.
Ashlesh
I am facing one more problem. while I am setting the browse button Text property to “…” it shows the some different value after open the form. I have attached its image here kindly go through it.
Thanks in advance.
Ashlesh
rejser
August 19, 2010, 11:35am
10
filepath is what I think you refer to as folder-path
I can’t choose a file, only folders. So I won’t get c:\files\textfil.txt, because I only se folders when I browse. So I can only get c:\files\
Oscar,
When i am setting the ExtendedDataType property to “FilePath” it automatically get the “Directory :” caption in front of my textbox.
Can you please suggest me some way to hide this “Directory :” caption.
Ashlesh
rejser
August 19, 2010, 12:29pm
13
Well, on the stringedit you could enter a label in the properties. Or set the property showlabel to no.
Directory is the default label of the Filepath extended datatype. That’s why it appears in front
/Oscar
It works fine.
Thanks for all your support,
Ashlesh
