Best Process for Nav Upgradation from 2009R2 to 2013R2
Hi Developers,
What is the Easy and Best process for Nav upgradation(2009R2 to 2013R2) With data Accuracy?
if any one have already done Give me some suggestions for the upgradation…
We are Going to Upgrade By following your Valuabale suggestion
Thanks In Advance
Help should be Appreciated
Thanks and Regards
Mahesh U
Hi Uppala,
For up gradation you need to follow certain process step by step followed by testing which will give correct data accuracy and upgrade
There is no easy process to upgrade the version of Navision you need to follow guidelines given by Microsoft.
If you have lot of customization in DB then try to map these customization with new version of Navision. There might be possibility that customization done in old version is now standard feature in Navision which will minimize the work.
You can follow link to upgrade
http://msdn.microsoft.com/en-us/library/hh167308(v=nav.70).aspx
try to look in for merge tool.
