Currently I am having NAV 2009 database (30% customized objects). I want to upgarde the same databse from NAV 2009 to NAV 2013 R2.
Could you please help me for same.
Note: I need step for customized database.
Graph
Graph
Please refer to the below link to have the step-by-step upgrade process with convers the technical upgrade from Nav 2009 to Nav 2013 R2
http://msdn.microsoft.com/en-us/library/hh169484(v=nav.70).aspx
For customized database you need to compare the object with the new version and then do the merging of object.
Here you need to decide which customization you need to take forward as it might be consider in new version of navision by MS.
