I know this is routine and repeated question. But am facing the problem. I copied the vhd files from my laptop to another desktop machine. When I was about to start the Dynamics AX Object Server5.0$01-AX593 service the following error comes:
“Windows could not start the Dynamics AX Object Server5.0$01-AX593 on Local computer”
I checked the dependencies - everything is in started state
I checked the Log on tab in the service properties - Set it to Local Computer
It is AX VPC 3.5 and it hasnt expired. As per event log the error is with “AOS doesn’t Start due to SQL login Error”
A runtime exception was detected. Details follow.
Message: Cannot open database requested by the login. The login failed.
Login failed for user ‘CONTOSO\Administrator’
have you restored any database ? any how do this and check… go to SQL → your db → tables-> dbo.userinfo (open) → see that your or admin login is there or not.
try resetting the login credentials for dynamics ax service account (in the service’s properties)
also check if the ax service account has proper user roles (datareader, datawriter, ddladmin) and has grant rights in the 2 stored procedures: createserversessions, and createusersessions in sql management studio
Hi, were you ever able to solve this problem and if so can you please let us know what you did? We are having the same issues with several of our VPC’s this week.
