Is there a way to pass custom parameters to a standard document service? More specifically, I would like to modify the Sales Order service to accept a string value that I can then access from the Axd class, without actually having to create a field on the underlying tables.
An example of this would be the DocPurpose on the SalesSalesOrder data object. I tried creating a similar parameter in that class but this is not visible in the data policies. I also don’t understand how I can then access this parameter from the AxdSalesOrder class.
Any suggestions would be greatly appreciated.
Thank you,
Peter
