Hi All, While i am exporting data to excel i get an error message " Excel not found" . I have checked automation server and excel object library application is not available. How can i get application registered in server. Should i install excel to application server? or should install and publish in citrix for all users. Best regards Anu
Yes , Excel needs to be installed on the machine from where you run the automation
Thanks John. Should we publish excel application in citrix for all users to avail this feature.
Install Excel on the Target Machine
