Hi everybody
Suppose i want a field in a table to display only a default value which has been set by me so how can I update it to my table.
For example: There is a table named ‘TaxWithholdTrans_IN’ in AX 4.0 which contains a field named ‘BankName’.
This table nearly contains thousands of rows and most of them are not containing bankname but I want all the records to display a default bankname as “HDFC”. Basically I just need to update old records bankname from null to “HDFC”.
I want to do the same for “ChallanNumber” and “ChallanDate” fields in that table.
So can anybody provide me a solution for that. If possible do send a code for that.
I tried the same with SQL statements using ‘update_recordset’ statement but its still not displaying any update in those fields of table.
