I am opening nav 2.x version in 5.0 SP1 and I created a sample XML port for the table 18 for the few fields.I tried to run the XML port from code unit using the following code.
Files.CREATE(‘C:/XML/asd.xml’);
Files.CREATEOUTSTREAM(Outs);
XMLPORT.EXPORT(50000,Outs);
Files.CLOSE;
where files is of type file and outs is of type outstream.
But when i run this code unit, the application restarts. Can any one please provide me a solution to run the XML port successfully!!!.
