Does anyone know if NAS will run XML Ports? (Since it still can’t run dataports [V])
Let’s follow the Commerce Gateway path…
- nas.exe ‘CG’ calls…
- Codeunit 1 - ApplicationManagement, which calls…
- Codeunit 99008528 BizTalk Appln. Srv. Startup, which may call…
- Codeunit 99008512 BizTalk Watchdog, which may call…
- Codeunit 99008514 XML Document-Send, which calls…
- Codeunit 99008517 XML Document-Create.
- Aha! – XML Document-Create runs XMLPorts!
- QED
Thanks Fritz, I would have tested it myself but the last two license updates I’ve had since 4.0 was released haven’t included the ability to access XMLPorts. [V] Hopefully my next update will… Cheers.
a bit off topic but For some reason Microsoft require you to ask for your license to be upgraded for v4.00 support. I suppose this is for internal monitoring of which version people are using. While I can understand this for customer licenses it seems a bit strange for developer licenses.
