I need some help adjusting the date format on my checks. Currently the date is in a mm/dd/yyyy format I need to change it to a dd/mm/yyyy format. It would also be helpful if I could add in some spacing between the day, month and year. I am trying to fit it into a predefined check layout on the printing paper. Below is the code that I currently have. any help that you can provide would be much appreciated.
For user interface situations, use strFmt or date2Str with -1 in all the formatting parameters. This ensures that the date is formatted in the way that the user has specified in Regional Settings.
