Date Format for a Cheque
Hello Everyone,
I want to display date in a cheque for one of my client. The date format should be dd mm yyyy . And this date should fix in eight boxes of a cheque.
Can anyone help me?
You need to split the date in Day,Month and Year then put in different text boxes to display in Cheque report
Thanks amol sir… I wrote this code for date format.
d := TODAY;
day := DATE2DMY(d,1);
Month := DATE2DMY(d,2);
year := DATE2DMY(d,3);
I got the format like this 18 03 2012 . But i need to print space between each digit so that it can fix easily in a cheque box. i.e : 1 8 0 9 2 0 1 2
for this, you have to take a array and split the digits and put them in array variables…
you can search the forum or you can check 13723 report in IN database…
Hi mohana… I dont have report by that number 13723.
You can try something like
ChequeDate := COPYSTR(FORMAT(“Cheque Date”,0,’<Day,2><Month,2>’),Index,1);
FOR Index := 1 TO 8 DO BEGIN
ChequeDate2[Index] := COPYSTR(ChequeDate,Index,1);
END;
hey dude,
how you solved this problem i have also same problem.
Manjul…
Did you try my above suggestion?
please try the code for date breakup.
CheckDateText := FORMAT(“Cheque Date”,0,1);
intDays := DATE2DMY(“Cheque Date”,1) ;
intMonth := DATE2DMY(“Cheque Date”,2) ;
IF STRLEN(FORMAT(intDays,0))=1 THEN
txtDate := ‘0’ + FORMAT(intDays,0)
ELSE txtDate := FORMAT(intDays,0);
IF STRLEN(FORMAT(intMonth,0))=1 THEN
txtMonth := ‘0’ + FORMAT(intMonth,0)
ELSE txtMonth := FORMAT(intMonth,0);
intYear := DATE2DMY(“Cheque Date”,3) ;
txtYear1 := COPYSTR(FORMAT(intYear),1,1) ;
txtYear2 := COPYSTR(FORMAT(intYear),2,1) ;
txtYear3 := COPYSTR(FORMAT(intYear),3,1) ;
txtYear4 := COPYSTR(FORMAT(intYear),4,1) ;
Thanks Rechard,
My problem is solved.
Manjul
Dear Sir,
Please provide the full function in VBA program. mean this format I need date in VBA 0 1 0 4 2 0 1 3 . Please reply as soon as possible
sir , please send format for excel / access use
