hi Experts,
i have little bit issuse regarding the check date
the date fromat in navision has for eg 20/05/2012
but i want my date should come like this 2 0 0 5 2 0 1 2
means a empty space between the date .
thanks in advance
shailesh
hi Experts,
thanks in advance
shailesh
May be you want to print in Blocks of Date Given in Checks…Am I Right?
The take a Array and copy each value in Array and show it…
hi Mohana,
thanks for the reply
but when iam making the array the data is not coming in the while iam running the report from RTC
shailesh
Where did you write the code?
Check report 13723 from HotFix-New Form16A and 27D…you will get idea…
HI MOHANA
Value := FORMAT(“Cheque Date”,0,’<Day,2>/<Month,2>/’);
Date[1] := COPYSTR(Value,1,1);
Date[2] := COPYSTR(Value,2,1);
Date[3] := COPYSTR(Value,4,1);
Date[4] := COPYSTR(Value,5,1);
Date[5] := COPYSTR(Value,7,1);
Date[6] := COPYSTR(Value,8,1);
Date[7] := COPYSTR(Value,9,1);
Date[8] := COPYSTR(Value,10,1);
THIS IS CODE IAM USING
IN THIS BOTH DATE AND VALUE ARE TEXT
BUT IT REFELCTING AN ERROR
TYPE CONVERSION NOT POSSIABLE
BECAUSE
CHARN := TEXT
HI MOHANA
BECAUSE
CHARN := TEXT
seperate date ,month, year in three different variables and display
hi amol,
iam not getting your point. can you please explain
split date in three different variables i.e date,month,year and display
actully while saving this code(which i have already put there) iam getting this error
Both the variable
date and value are text variable
but while compiling this iam getting this error
BECAUSE
CHAR:= TEXT
i have solve the problem,
thanks every one
regards,
shailesh
