I added one field in InventSum Table, it’s just to describe item name so it is searchable. The problem is, it is shows “Unretrieved” in OnHand form while it Table browser already correct.
I have search the web but all I can find is try to Compile, synchronize and restart AOS which already did.
If you are newly adding a field in the table, but table has some records. So please assign the value to that newly created field. so for that record sql will fetch the data from the table
Unretrived means SQL unable to fetch record from table.
Please let me know if any more clarification required …
In Invent on hand form , you can add InventTable datasource and link it with Inventsum table and you can use NameAlias field of InventTable to filter the item based on the name.
