Currently I keep track of FA Code details. I want to add a field (Transfer Code)on table FA Journal Line and when I posted it will record (Transfer Code) at table FA Ledger Entry.
What should I do ? And modified CodeUnit.
You need to added the field to your two tables and then use Debugger (or Go To Definition) to find exactly which codeunit or whatever is used to transfer from Journal to Ledger table.
