Hello Erik P. Ernst
I tried to reply to your comment related to SQL to NAV conversion but get then following error:
Access Denied: Reply Permission Denied (I don’t understand I have subscribed to this forum)
I had in mind asking you about where I can get information about : NAV source code format
as in your statement :
output the SQL database definitions in NAV source code format. Although if you’re not familiar with NAV, then it would take you a lot of tries and tests as the source code format must 100% precise down
regards
