We have a Server 2008 Standard 64bit install running SQL Server 2008 64bit SP1. Is there a 64bit NAV Server install to go with it?
the CSide-Client Executable is a 32 bit Program, and I think the Role tailored client is as well (of course they also run on a 64-bit Operating System).
The Extended Stored Procedure, that you have to add in order to use Windows Login with NAV on a SQL Server, comes with a 32-bit and a 64-bit Version.
Moved from NAV Beginner to NAV Technical.
