In WSS configuration process the following error occured which stopped my Configuration.
Access Denied [Exception from HRESULT 0X80070005] [E_Access denied]
Please help me to solve the issue.
I tried the below steps. BUT ITS NOT WORKING.
Identify the drive on which ProjectServer was installed.
Open a command prompt on the front-end servers (where the error is occurring) and navigate to the following path:
C: \Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\bin
Once you have arrived at the bin directory, type the following command:
Psconfig –cmd upgrade –inplace b2b –wait -force
Note: Since C: is the default path for the Project Server installation, C: has been used in this example. If a different drive letter has been used, use that drive letter instead.
This process will finalize any updates prior to implementing the fix. -
Once this process has completed, open the registry editor
Start=>Run=>Regedit
Once the registry editor has been opened navigate to
HKLM\System\CurrentControlSet\Control
Here it will be necessary to create a new DWORD key with the following value:
ServicesPipeTimeout DWORD 60000 (decimal)
Note: 60000 = 60 Seconds. -
Next, look for the WaitToKillServiceTimeout key – take note of its current value – and then change the value to 120000
Note: 120000=120 Seconds. -
Reboot the Server.
