Hi World,
Just want to ask help for my work center set-up. I have a client that is into Steel Fabrication. They have 12 Manpower to complete the Fabrication process, and after 25 minutes of fabrication, they can produce 1 unit. Anyway, their Process is Fabrication> Painting> Assembly. I believe fabrication is composed of different processes like Laser, Punching, Bending, welding, etc. And each process has its respective machine. Moreover, in a certain process like Welding, it can be done in one of the 5 machines.
What I did is set-up work center group(Welding) with a type “machine” and indicated 5 work centers in that group.
Queries:
Is it possible to indicate that there are 12 people operating the fabricating machines? (considering that type is Machine and not Human resources) In what way?
Since my set-up is per work center group, I believe specifying the 25 minutes of fabrication cannot be entered. However, indicating the time per process/ operation is the best way, am I right? Or is it still possible to indicate the 25 minutes Fabrication run time?
If answer for no.1 is NO, in what way can I trace the operators job for that machine where I can link it the production module?
Hope you can help me with my concerns!
Thanks a lot in advance for the help!
Jr Barte
